show ldap domain
show ldap domain {domain_name | all}
Description
This command displays the LDAP servers and other LDAP configuration details of one or all LDAP domains.
Syntax Description
domain_name
Displays the details of the specified domain.
all
Displays the details for all domains.
Default
N/A.
Usage Guidelines
Use this command to display the LDAP servers and other LDAP configuration details of one or all LDAP domains. The summary version (show ldap domain) displays the list of LDAP domains configured.
# show ldap domain
LDAP Domains
XYZCorp.com (Default)
engg.XYZCorp.com
mktg.XYZCorp.com
sales.XYZCorp.com
If no default domain is configured, this note appears at the bottom:
Note: No default domain configured
# show ldap domain all
Domain(default) : XYZCorp.com
Base-DN         : XYZCorp.com
Bind credential : jsmith
LDAP Hierarchical Search OID   : LDAP_MATCHING_RULE_IN_CHAIN (1.2.840.113556.1.4.1941)
LDAP Configuration for Netlogin:
dot1x         : Enabled
mac           : Enabled
web-based     : Enabled
LDAP Server 1         : 192.168.2.101
Server Port        : 389
Client IP          : Any
Client VR          : VR-Mgmt
Security Mechanism : Plain Text
Status             : Active
LDAP Server 2         : 192.168.2.102
Server Port        : 389
Client IP          : Any
Client VR          : VR-Mgmt
Status             : Not Active
Domain          : engg.XYZCorp.com
Base-DN         : engg.XYZCorp.com
Bind credential : pkumar
LDAP Hierarchical Search OID   : 1.2.840.113345.1.4.1789
dot1x         : Enabled
mac           : Enabled
web-based     : Enabled
LDAP Server 1         : engsrv1.engg.XYZCorp.com(192.168.3.101)
Server Port        : 389
Client IP          : 192.168.10.31
Client VR          : VR-Mgmt
Status             : Active
LDAP Server 2         : 192.168.3.102
Server Port        : 389
Client VR          : VR-Mgmt
Status             : Not Active
Domain          : it.XYZCorp.com
Base-DN         : it.XYZCorp.com
Bind credential : asingh
LDAP Hierarchical Search OID   : None
dot1x         : Enabled
mac           : Enabled
web-based     : Enabled
LDAP Server 1         : 192.168.4.101
Server Port        : 389
Client VR          : VR-Mgmt
Status             : Not Active
LDAP Server 2         : 192.168.4.102
Server Port        : 389
Client VR          : VR-Mgmt
Status             : Active
Domain          : mktg.XYZCorp.com
Base-DN         : mktg.XYZCorp.com
Bind credential : gprasad
dot1x         : Enabled
mac           : Enabled
web-based     : Enabled
LDAP Server 1         : mktgsrv1.mktg.XYZCorp.com(192.168.5.101)
Server Port        : 389
Client IP          : Any
Client VR          : VR-Mgmt
Status             : Active
LDAP Server 2         : 192.168.5.102
Server Port        : 389
Client IP          : Any
Client VR          : VR-Mgmt
Status             : Not Active
Domain          : sales.XYZCorp.com
Base-DN         : sales.XYZCorp.com
Bind credential : masiq
dot1x         : Enabled
mac           : Enabled
web-based     : Enabled
LDAP Server     : No LDAP Servers configured
# show ldap domain “engg.XYZCorp.com”
dot1x         : Enabled
mac           : Enabled
web-based     : Enabled
Server Port        : 389
Client VR          : VR-Mgmt
Status             : Active
Server Port        : 389
Client VR          : VR-Mgmt
Status             : Not Active
If the server was specified as a host name and the IP address was not resolved, this is shown:
LDAP Server1   : server1.domain.com(IP address unresolved)
This command was first available in ExtremeXOS 15.2.
Platform Availability
